OctaneRender™ for Blender 2024.1 - 29.14 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
FIXES SINCE LAST RELEASE
  • Fixed an "empty ramp" problem when using ramp nodes(Gradient map, Toon ramp, Volume ramp)
  • Fixed some bugs as for the Cycles wrapper node
  • Fixed a render issue when using vertical camera sensor
  • Fixed offset problem when applying "camera dimension as preview resolution"
  • Fixed some other render issues of "camera dimension as preview resolution"
  • Fixed a material converter issue
  • Fixed a Vectron node render issue
  • Fixed crash when right clicking on the Server icon
  • Fixed renaming material update issue
  • Fixed crash when using empty image
HOTFIXES 29.14.1 (27/09)
  • Fixed Render Viewport Bug
You can read about new features of OctaneRender™ 2024.1 here:
viewtopic.php?f=24&t=83998
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.14.1 (4.2.1)
Octane Server - Studio+ Edition - 29.14
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
