Cinema4D version 2024.1-[R3] latest stable (11.10.2024)
Hi all,
This is the plugin build based on OctaneRender® 2024.1 stable SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching OctaneRender® 2024.1.
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 522. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models. On macOS, only the CPU version is supported.
As with all experimental builds, we advise to not use this release for production purposes. We are trying to, but we can't guarantee that scenes saved with this version will be compatible in future releases. Changes are still being made daily.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2024.1-R3 plugin revisions
  • Wrong orientation for "direct lights" on 2024.1
  • missing components on layered material > metal layer
  • Changed "Cloud" menu entries
  • Fixes on Vectron operators
  • UX revisions with unstable Cryptomatte types
2023.1.3-R2 plugin revisions
  • Fix: crash cases of previous release which are related with GPU activation procedures
WINDOWS STUDIO+ 2024.1-[R2] (R21-R2025)
https://render.otoy.com/customerdownloa ... R3_win.rar
WINDOWS STUDIO+ DEMO 2024.1-[R2] (R21-R2025)
https://render.otoy.com/plugindownloads ... R3_win.rar
Mac OSX Prime 2024.1-[R2] (R25-R26/R2023/R2024/R2025)
https://render.otoy.com/plugindownloads ... SX.zip.zip
Please note the macOS build below will only work correctly on macOS 13.3 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.1.0). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
gsgorcun
Downloaded zip file for Windows contains 2024 Beta 3 version not 2024.1, fyi.
Note: When the Imager is ENABLED it causes lag in the C4D viewport. Thanks Raphael Rau for confirming that.
Here is a video capture showing the issue on C4D 2025:
https://streamable.com/9dk1x2
Also tested on C4D 2024.5.1 and causes same issue.
Scene file download link: https://greyscalegorilla.com/free-scene ... or-octane/
Anlv
gsgorcun wrote:Image
You are right, my title is also 2024_beta_3
3D Motion Graphics Designer / E-commerce Designer
13700K / 64GB / 4090 / PSU 1250W
Thanks for reporting these!
I'm gonna fix the title issue, it's an overlook for the title string.
Could you see the lag on your scenes else of that?
WDH
Sadly unicode charactor is still missing
twik25
I'm getting a lot of crashes doing simple tasks (like dropping a material onto an object, or changing IOR). I believe I have isolated it to having cards with RTX mixed with non-RTX cards and having RTX acceleration turned on. These crashes are new with either C4D 2025 or the 2024.1 release, as I did not have this issue on C4D2024 with the Beta.
The other thing I have noticed is that when I change values, it takes a long time to update the picture viewer, but if I change cameras it almost updates instantly. This slowdown was not release 2023. This slowdown is in Beta 3 tested on C4D 2024, although not quite as bad. I don't remember noticing it in Beta 1 & 2, and I can't download those versions to test. I have tested with multicore for LV, texture caching, multi-threading, opengl previews, and faster viewport textures on & off with no difference noticed. **Just tested in standalone, and this is a C4D issue, not core**
Nvidia driver version 536.99.
Windows 10.
C4d R25.
Crash Logs and Videos >> https://drive.google.com/drive/folders/ ... sp=sharing
eyeonestudio
Could you please add support for R19 when compiling?
R19 is the last version that can open scenes created with older plugins and versions prior to R19 correctly.
It's really unfortunate that R19 support has been excluded.
As a developer, I understand that you don't have much time for bug fixes and new development.
I kindly ask for your consideration.
Thank you
gsgorcun
aoktar wrote: Thanks for reporting these!
Hi, I didn't notice any lags when Imager is not enabled. I also tested with a basic scene which doesn't have any materials and I was able to reproduce the lag when Imager is enabled. You can check the video from the link:
https://streamable.com/onsnwj
It would be great if we can have Octane 2023.1.3-R6 for C4D 2025. If possible of course. Thanks in advance.
Kalua
Thanks for the Update, Aoktar.
Looking good so far.
One question: check the image, that's the "real-time rendering" button on standlaone.
What's the respective option inside C4D?
Regards,
Screenshot 2024-09-13 182814.jpg (2.36 KiB) Viewed 22833 times
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
lastdrog
Hi!
Have an issue with VDB render. Render time is huge comparing to 2023 version.
Here is a post with video and pictures: viewtopic.php?f=30&t=84019
You can see huge time render difference :
Can anyone help to understand the problem? Thanks.
