OctaneRender™ for Blender 2024.1 - 29.13 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Blender 4.2.1
  • Update to Octane 2024.1
FIXES SINCE LAST RELEASE
  • Fixed empty mesh problem caused by wrong shader index
  • Fixed redundant updates caused by false positive shading updates
You can read about new features of OctaneRender™ 2024.1 here:
viewtopic.php?f=24&t=83998
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.13 (4.2.1)
Octane Server - Studio+ Edition - 29.13
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
