OctaneRender™ for Blender 2024.1.Beta.3 - 29.12 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Blender 4.2
  • Updated to Octane 2024.1.Beta3
  • Implemented Cycles wrapper nodes(color mix, float mix, and math nodes)
  • Implemented Octane viewport pickers(material, white balance, and focus pickers)
  • Supported updating preview render when reloading images from an external editors
FIXES SINCE LAST RELEASE
  • Fixed ramp node update issues
  • Fixed render issue when switching between preview and final render
  • Fixed redundant mesh update issue in edit mode
You can read about new features of OctaneRender™ 2024.1 Beta 3 here:
viewtopic.php?f=33&t=83926
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.12 (4.2.0)
Octane Server - Studio+ Edition - 29.12
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
