Live Viewer causes C4D to crash
Fred23
I have a problem with the Live Viewer (like some others):
I am having some problems with Octane for Cinema4D 2023.
I use a MacBook Pro M2 Max with Ventura installed.
-Cinema 4D crashes when I close Live viewer.
Do anybody has the same issue?
Paolo
I wrote to Beppe a long time ago. Unfortunately, the problem could not be solved. Is there a solution in the meantime?
And: C4D does not crash directly when rendering in the image manager. But: C4D only freezes when you close it.
So unfortunately I can only work with octane with difficulty.
Fred
MacBook Pro M1 Max, 64 MB Ventura 13.6.6., C4D 2024.5.1
LucasNathann
Did you fix the problem?
the issue while closing Live View has been fixed some time ago.
If you are still having issues, please write to help at otoy dot com asking for Beppe, thanks.
ciao,
Beppe
