VDBs not exporting to Standalone
Whispermode
Hi guys,
I have a Blender scene with 8 lightweight (1 second burst) VDB sequences.
When I export to Standalone (to prep for RNDR), they don't appear, and I have to remap them all - the object layers(?) are there, but with no sequence inside.
It's a pain to remap every time I want to do a a test render.
Any ideas?
Thanks in advance.
linograndiotoy
Which version? Custom? Addon?
I'll try here in the most updated one and let you know.
Whispermode
Latest Stable (28.16)
I've figured it out - not sure if it's a bug or not.
If I duplicate the VDB Object (I have done 8 times), and then make the data-blocks single user (because I want to start the sequences at different times, so have to do that), it won't import to Standalone.
I guess the fact that you can remap the VDB sequences in Standalone means it is a bug (?)
Whispermode
Solved - it isn't what I thought it was...
You have to change the 'Sequence playback mode' to 'Extend' (I had it on 'Clip'), so that it registers from frame 1 (if you are delaying the frame start point).
linograndiotoy
It was working correctly here with one VDB. Thanks for your insight!
Return to “Blender”
