OctaneRender™ for Blender 2024.1.Beta.2 - 29.10 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Blender 4.1.1
  • Updated to Octane 2024.1.Beta2
  • Supported converting Cycles' Color Mix node
  • Do not create new kernels when applying presets
FIXES SINCE LAST RELEASE
  • Fixed bugs when converting legacy nodes
  • Rename "Prefer Image Type" to "Final Render Image Type" as it is only valid in Final Render
  • Minor bug fixes
You can read about new features of OctaneRender™ 2024.1 Beta 2 here:
viewtopic.php?f=33&t=83653
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.10 (4.1.1)
Octane Server - Studio+ Edition - 29.10
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 29.10
