Universal light Massive Lag
Houdini Integrated Plugin
Terryvfx
I tried the latest production and beta releases and I noticed that every time I click on any setting from the Universal Light it lags massively, I'm stalking about 3 to 8 seconds the program freezing, is this the expected performance or is it some kind of bug were it re-uploads the scene constantly?
The scene that I'm doing only contains a single shoe model not even 100mil polys and some displacement..
I'm running 20.0.751
Linux Pop!_OS 22.04lts
550 Nvidia Drivers
ricky_otoy
Are you using Modify? Is it only gradient or any parameter you adjust?
Please PM me your scene and we can have a look.
Note that Universal is not a special light type and added only for convenience in Houdini - especially the Modify tab. Because it is layer based it will degrade some UI performance when gradients are used, this is a known issue and we will try see if we can optimize somehow. The other original lights are much more light weight and may be better suited for some cases.
Return to “Houdini”
