I've been using Octane Blender on MacBook Pro M2 for a little while now, but since yesterday I keep having a very annoying error and I don't know how to fix it, can anyone help ?
The error :
Can't connect node 'OCTANE_BLENDER_RENDER_PASS_NODE' (NT_TEX_SPOTLIGHT, 0x13d62d720) to static pin 'renderPasses' (P_RENDER_PASSES, type PT_RENDER_PASSES) of node 'Render target' (NT_RENDERTARGET, 0x13f9157d0)
Can't connect node 'OCTANE_BLENDER_RENDER_PASS_NODE' (NT_TEX_SPOTLIGHT, 0x13f82b910) to static pin 'renderPasses' (P_RENDER_PASSES, type PT_RENDER_PASSES) of node 'Render target' (NT_RENDERTARGET, 0x13f814240)
Tried to access null node pin
Tried to access pin via an invalid ID P_MAX_UPSAMPLING_INTERVAL (494)
can't read int/enum from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x11334d688)
Can't write int to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x11334d688)
tried to send change event for null item or empty pin array
Tried to access pin via an invalid ID P_UNKNOWN (0)
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x11334d688)
Tried to access pin via an invalid ID P_OLD_VOLUME_BEHAVIOR (448)
Tried to access pin via an invalid ID P_USE_OLD_COLOR_PIPELINE (708)
Compute error 2097152:6199234486295259741:3348:
Compute error 2097152:6199234486295259741:3348 on device 0:
device 0: path tracing kernel failed
