C4d Crashing when using Octane Scatter
emilaga151
I have been using the same computer/c4d setup for 2-3 years now with no issue but lately I have had projects crash on me when I use Octane scatter in the scene and attempt to render. After c4d freezes or crashes and I try to open the file again I get the "incorrect file structure" prompt. Sometimes the scenes are very simple and there are no complex high-poly structures. The scattering is low as well.
I have attached my most recent crash report if anyone can help me understand why my files keep crashing I would appreciate it.
c4doctanelog.txt
(14.02 KiB) Downloaded 96 times
please write to help at otoy dot com, so we can investigate more deeply.
ciao,
Beppe
JeromeZhu
我也碰到过这样的问题,如果你在使用c4d时,碰到了停电,就会导致“文件结构不正确”的提示。好像只能使用自动保存的文件继续 工作了。
I have also encountered such a problem, if you are using c4d, encountered a power outage, it will lead to the "incorrect file structure" prompt. It seems that I will have to continue working with auto-saved files.
