Hello,
When using point or vertex float or vector attributes, is it possible to modify the bit depth to 16bit, or lower?
If I manually quantize attributes to 16bit in SOPs, the memory footprint is reduced.
However, if I render with and without this attribute quantization, the VRAM memory foot print does not change at all.
Is there a way to get octane to read 16bit floats to optimize memory usage?
Even if you save out geometry with attributes all as zero, it still seemingly allocates full 32bit memory for each attribute.
Looking for something akin to the channelFormat parameter on the Texture Image RGB material node, but for geometry attributes, instead of image depth.
Thank you for you time,
Tighe
16bit Point & Vertex Attributes
- ricky_otoy
Hi there, we are busy investigating if this is a possibility for the vertex attributes.
I will let you know! Thanks for reaching out.
- ricky_otoy
Hi there, ok I can now confirm this is not possible.
- ricky_otoy
It is not something that we can add in Houdini, it is a current API requirement as far as I know.tigher wrote:Hi, thank you for investigating, this feature would be highly desirable.
Could this please be added as a feature request? I imagine that many users of Octane would jump at any opportunity to lower VRAM usage.
Thank you for your time,
Tighe
I will ask about it though
