vertex color tag rendering problem
Ofcourse
Hello, is there a way how to render out vertex color tag with Octane, because when I drag and drop that tag into node editor and plug it in the desired input... All just freeze
I cannot use even the already baked alembic with vertex color tag on it in octane, all just freeze when I plug this node into port... Any thoughts? All with latest version
The way is how you do most likely. We can help more if you share enough data to give use ideas about your content and process.
Ofcourse
My problem with just drag and drop vertex color tag into node editor and then plug this node into material channel causes completely freezes C4D , so have fixed this using Vertex Map node and then drag that vertex color tag into this node field, all works fine in this way... So I had to use Vertex color node to reference my desired vertex color tag... this node works for me without any problem so far.
I have been using Attribute node for referencing colors from trails etc. But it is interesting I can use it even with vertex map like it is shown in documentation :)
