OctaneRender™ for Blender 2024.1.Beta.1 - 29.9 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Support volume speed multiplier
FIXES SINCE LAST RELEASE
  • Fix preview update issue when renaming material
  • Fix object layer update issue of Analytical lights
  • Fix flickering rendering as to the volume
  • Fix the missing "Adapt to Camera Resolution" option
HOTFIXES - 29.9.1 (04/06)
  • Fix Render Preview issue - attributes that are modified via a Driver now update correctly in Render Preview
You can read about new features of OctaneRender™ 2024.1 Beta 1 here:
viewtopic.php?f=33&t=83506
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.9.1 (4.0.2)
Octane Server - Studio+ Edition - 29.9
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
