OctaneRender™ for Blender 2023.1.3 - 28.15 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Adjust the default value of motion blur and deformation as False
  • Add an operator to sync the motion blur settings to children objects of a linked collection
  • Support to use the object itself as the input of scatter surface
FIXES SINCE LAST RELEASE
  • Fix tiled image resource cache malfunctioning issue
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2023.1.3 here:
viewtopic.php?f=24&t=83348
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.15 (4.0.2)
Octane Server - Studio+ Edition - 28.15
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
