Denoise in camera
Hydra Solaris
seriawp
I created a camera_edit node and enabled "enable Denoising". But the image is still rendered without a denoizer. Why?
k3xx
You have to put down an Octane AOV node and turn on denoise beauty pass. Then you can switch to the denoised pass in the viewport (there is a small button on the right) or find your pass in the rendered exr.
seriawp
thank you!
BK
k3xx wrote:You have to put down an Octane AOV node and turn on denoise beauty pass. Then you can switch to the denoised pass in the viewport (there is a small button on the right) or find your pass in the rendered exr.
Thank you K3xx for your help
cheers
Kind Regards
bk3d
Return to “Hydra Solaris”
