OctaneRender™ for Blender 2023.1.3 - 28.14 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Update to 2023.1.3
  • Implement two f-stop modes
  • Add Auto f-stop mode to convert the f-stop to aperture before syncing to engine
  • Add Legacy f-stop mode for backward compatibility.
  • Set object motion blur option as True by default
  • Optimized objects/collections linking performance
  • Supported motion blur for panoramic camera
FIXES SINCE LAST RELEASE
  • Fixed the huge slowdown when copying color ramp data
  • Fix crash caused by Postfix Media pass
  • Fix a particle emitter rendering issue
  • Fixed motion blur rendering issue of universal camera
  • Fixed an animation rendering crash
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2023.1.3 here:
viewtopic.php?f=24&t=83348
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.14 (4.0.2)
Octane Server - Studio+ Edition - 28.14
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
