Hi all,
This is the plugin build based on OctaneRender® 2024.1 Beta 3 SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching OctaneRender® 2024.1 Beta 3.
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 522. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models. On macOS, only the CPU version is supported.
As with all experimental builds, we advise to not use this release for production purposes. We are trying to, but we can't guarantee that scenes saved with this version will be compatible in future releases. Changes are still being made daily.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS STUDIO+ 2024.1_Beta_3 (R21-R2024)
https://render.otoy.com/customerdownloa ... a3_win.rar
WINDOWS STUDIO+ DEMO 2024.1_Beta_3 (R21-R2024)
https://render.otoy.com/plugindownloads ... a3_win.rar
Mac OSX Prime 2024.1_Beta_3 (R25-R26/R2023/R2024)
https://render.otoy.com/customerdownloa ... -Beta3.zip
WINDOWS STUDIO+ 2024.1_Beta_2 (R21-R2024)
https://render.otoy.com/customerdownloa ... _2_win.rar
WINDOWS STUDIO+ DEMO 2024.1_Beta_2 (R21-R2024)
https://render.otoy.com/plugindownloads ... _2_win.rar
Mac OSX Prime 2024.1_Beta_2 (R25-R26/R2023/R2024)
https://render.otoy.com/customerdownloa ... _Beta2.zip
Please note the macOS build below will only work correctly on macOS 13.3 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.1.0). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
Cinema4D version OctaneRender® 2024.1_Beta_3 (04.09.2024)
Hard freezes while rotating viewport using LV if it still being rendering.
Compared to Standalone version or C4D 2023 version Octane nodes doesn't work in realtime using other input methods than slider dragging - input values manually or using arrows cause 2-3 seconds lag. If during this lag I rotate/move viewport Octane will freeze. Also I noticed that Standalone LiveViewer works faster - it is much more responsible using larger viewport sizes.
You need C4D 2024.4.0Delizade wrote:Hello,
When I install the plugin on Macbook Pro M3, MacOS 14.4.1, and C4D version 2024.2, Octane plugin doesn't load.
However, the previous alpha version works. How can I solve this issue?
Thank you.
Hello,
Thank you for this releases, just dig only few days on it and I'm already excited by new features!
For now yes, you can't really use it for production, neither rendering files from what I feel. When I wanna launch a render, from render queue or picture viewer, it's failing automatically.
Attached, my bugreport if you wanna tell me how to fix this.
W11 Pro, C4D 2024.4.0, Octane Render 2024.1_Alpha4 (project is Basic texture with nothing much diffuse-opacity-bump and a little clothe simulation moving)
best,
best,
- Attachments
- _BugReport.txt
- (850.07 KiB) Downloaded 251 times
- astrofalcon
- Contact:
Is this the latest 2024 release? Or is there a beta now?
viewforum.php?f=85astrofalcon wrote:Is this the latest 2024 release? Or is there a beta now?
- astrofalcon
- Contact:
Thank you, yeah I'm aware of the main releases page but Matt and Dave were talking about an official "Beta 2" that was up and I didn't know where I can get this "Beta 2" https://www.youtube.com/watch?v=BlezbBmciyMfrankmci wrote:viewforum.php?f=85astrofalcon wrote:Is this the latest 2024 release? Or is there a beta now?
