I am urgently trying to get a draft render out for a client review but can't successfully get a consistent render going without crashes after 9-20 frames.
I have 1,3m polys in my scene, using C4d 2024.3.2, and the latest Octane. I have tried on my Macbook M1, and my Windows machine, but I can't manage to get more than a handful of frames exported before crashing.
Windows - RTX 3080, GTX 1080ti
The main issue seems to be 'CUDA error (700) on device 1: an illegal memory access was encountered'. Is this just a case of allowing more memory in the Device 1 OOC?
If anyone could help me understand the following error log, and also guide me in to running successful renders on this particular issue & project, I would be incredibly helpful.
Started logging on 23.04.24 10:31:33
OctaneRender Studio+ 2023.1.2 (13000200)
VRAM used/free/max:0Kb/10Gb/10Gb Out-of-core used:0Kb RAM used:18.664Gb total:63.883Gb OpenGL free/total:0/0
FRAME:0 fps:25
--------------------------- EXPORT LOG ---------------------------
Export materials time= 158236.229 ms
Collect objects time= 9.823 ms
Mesh creation time = 558.569 ms.
MB:0/0 ST/MOV:0/68 Nodes:197 Tris:3.633m DispTris:0 Hairs:0 Meshes:1k
Textures Grey8/16:11/0 Rgb32/64:50/0
VRAM used/free/max:3.465Gb/3.028Gb/10Gb Out-of-core used:0Kb RAM used:26.766Gb total:63.883Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=0sec. updateTM=0sec. renderTM:3.497sec. totalTM:166.201sec.
FRAME:1 fps:25
MB:0/0 ST/MOV:0/104 Nodes:198 Tris:6.189m DispTris:0 Hairs:0 Meshes:1k
VRAM used/free/max:3.929Gb/2.503Gb/10Gb Out-of-core used:0Kb RAM used:26.243Gb total:63.883Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=0.701sec. updateTM=1.309sec. renderTM:4.085sec. totalTM:6.182sec.
FRAME:2 fps:25
FILE is not found:P:\\Projects\Nichols\SS24\Land\Land 1 Project\Land 1 Main\tex\HN Land Plate 1 v2 000_2.png
MB:0/0 ST/MOV:0/143 Nodes:270 Tris:9.213m DispTris:0 Hairs:0 Meshes:1k
VRAM used/free/max:4.47Gb/1.761Gb/10Gb Out-of-core used:0Kb RAM used:28.338Gb total:63.883Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=1.214sec. updateTM=2.141sec. renderTM:5.079sec. totalTM:8.474sec.
FRAME:3 fps:25
FILE is not found:P:\\Projects\Nichols\SS24\Land\Land 1 Project\Land 1 Main\tex\HN Land Plate 1 v2 000_3.png
MB:0/0 ST/MOV:0/183 Nodes:348 Tris:12.393m DispTris:0 Hairs:0 Meshes:1k
VRAM used/free/max:5.039Gb/1.131Gb/10Gb Out-of-core used:0Kb RAM used:30.307Gb total:63.883Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=1.679sec. updateTM=2.841sec. renderTM:5.924sec. totalTM:10.482sec.
FRAME:4 fps:25
FILE is not found:P:\\Projects\Nichols\SS24\Land\Land 1 Project\Land 1 Main\tex\HN Land Plate 1 v2 000_4.png
MB:0/0 ST/MOV:0/225 Nodes:428 Tris:15.884m DispTris:0 Hairs:0 Meshes:1k
VRAM used/free/max:5.664Gb/505Mb/10Gb Out-of-core used:0Kb RAM used:32.862Gb total:63.883Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=2.259sec. updateTM=4.038sec. renderTM:7.063sec. totalTM:13.407sec.
FRAME:5 fps:25
FILE is not found:P:\\Projects\Nichols\SS24\Land\Land 1 Project\Land 1 Main\tex\HN Land Plate 1 v2 000_5.png
MB:0/0 ST/MOV:0/269 Nodes:512 Tris:19.688m DispTris:0 Hairs:0 Meshes:1k
VRAM used/free/max:6.345Gb/0Kb/10Gb Out-of-core used:0Kb RAM used:41.838Gb total:63.883Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=2.808sec. updateTM=6.344sec. renderTM:7.936sec. totalTM:17.129sec.
FRAME:6 fps:25
FILE is not found:P:\\Projects\Nichols\SS24\Land\Land 1 Project\Land 1 Main\tex\HN Land Plate 1 v2 000_6.png
device 0: disabling RTX acceleration as mesh data cannot be placed into VRAM
MB:0/0 ST/MOV:0/315 Nodes:600 Tris:23.803m DispTris:0 Hairs:0 Meshes:1k
VRAM used/free/max:5.668Gb/539Mb/10Gb Out-of-core used:384Mb RAM used:44.361Gb total:63.883Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=3.572sec. updateTM=7.575sec. renderTM:25.657sec. totalTM:36.844sec.
FRAME:7 fps:25
FILE is not found:P:\\Projects\Nichols\SS24\Land\Land 1 Project\Land 1 Main\tex\HN Land Plate 1 v2 000_7.png
MB:0/0 ST/MOV:0/363 Nodes:692 Tris:28.23m DispTris:0 Hairs:0 Meshes:1k
VRAM used/free/max:6.75Gb/0Kb/10Gb Out-of-core used:1.125Gb RAM used:43.04Gb total:63.883Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=4.223sec. updateTM=22.331sec. renderTM:15.845sec. totalTM:42.438sec.
FRAME:8 fps:25
FILE is not found:P:\\Projects\Nichols\SS24\Land\Land 1 Project\Land 1 Main\tex\HN Land Plate 1 v2 000_8.png
MB:0/0 ST/MOV:0/413 Nodes:788 Tris:32.969m DispTris:0 Hairs:0 Meshes:1k
VRAM used/free/max:5.687Gb/481Mb/10Gb Out-of-core used:1.591Gb RAM used:44.905Gb total:63.883Gb OpenGL free/total:0/0
-> failed to synchronize event
device 1: path tracing kernel failed
Check geometry subdivisons.
Picture viewer uses 'Render' subdivisions. But Live Viewer uses 'Editor' subdivision values.
Try to decrease 'render/editor' subdivison values.
CUDA error (700) on device 0: an illegal memory access was encountered
device 0: path tracing kernel failed
-> failed to destroy CUDA event
-> failed to deallocate pinned memory
-> could not get memory info
-> failed to deallocate device memory
-> failed to deallocate device array
Failed to free page-locked memory
OptiX error for device 0: [PIPELINE] Error synching on OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
Error destroying OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
OptiX API error for device 0: CUDA error
Break rendering...
**** RENDER FINISHED **** stat=3
Help Understanding Error Log - CUDA Error 700
in general, CUDA 700 error is caused by corrupted or not correctly installed Nvidia driver.
Please, try to perform a clean installation of 552.22 Nvidia Studio driver:
https://www.nvidia.com/download/driverR ... 156/en-us/
To perform a clean installation, please follow these steps:
After reboot, if not enough, try to connect the monitor to GTX 1080, and use RTX 3080 for octane only.
Keep us informed.
ciao,
Beppe
Keep us informed.
ciao,
Beppe
- Tim_Twisted
For me this sounds like not enough VRAM to handle the scene. Especially looking at the log
Frame 8:
481Mb shouldn't crash but is close enough for me to remove some stuff in the scene and see if the crash persists.
Frame 8:
Yes, there is definitely an issue with memory, since geometry is growing by 3 millions polys per frame.
It starts at 3 millions at frame 0, and ends at 33 millions at frame 8.
Out-of-core has to be activated from frame 6, so it seems that you don't have enough memory for rendering this scene.
Could you share the scene via PM?
ciao,
Beppe
ciao,
Beppe
this fixed it for me : Ok, please use the following Nvidia tool:
https://developer.nvidia.com/cleanup-tool
Then please perform a clean installation of 576.80 Nvidia Studio driver:
https://www.nvidia.com/en-us/geforce/drivers/results/247854/
