OctaneRender for Maya 2024.1alpha4-23.10 [OBSOLETE]
Locked
Forum rules:
NOTE: The software in this forum thread is not 100% reliable, this is a development build and is meant for testing by experienced octane users. If you are a new octane user, we recommend to use the current stable release.
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSE THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya®: OctaneRender™ 2023
Maya® Version Requirements
This release will work with Maya® Versions 2019, 2020, 2022, 2023 and 2024 64-bit on Windows, MacOS and Linux systems.
Changelog and the installers for Octane Standalone 2024 are here:
OctaneRender Standalone 2024
Changes since 23.3:
  • Integrated the 2024.1 Alpha4 engine.
  • Implemented USD support, in the first DRAFT. This is not for production work so far, just for testing. It is still being developed further, the USD scene format may be changed in further versions and might not be compatible with upcoming STABLE 23.X releases...
  • Fixes and improvements...
NOTE: No macOS version at this time. It will follow later, 'cause it needs some re-work: Octane SDK for macOS does not support Intel x64 anymore. And Maya SDKs prior to 2024 do not support ARM. So because of it the plugin's macOS versions from now on will not support any Maya versions prior to 2024. If you're on Mac and older Maya version - you can use the plugin's 22.X stable branch as a fallback, or upgrade Maya to at least 2024, or switch your machine to either Linux or Windows.
Subscription Studio+ Downloads
OctaneRender for Maya Studio+ [Windows]
OctaneRender for Maya Studio+ [Linux]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
Locked
