OctaneRender™ for Blender 2024.1.Alpha.3 - 29.5 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Support using object layer map as inputs of scatters
  • Support open subdivision for curves
FIXES SINCE LAST RELEASE
  • Fix emission texture link problem
  • Fix some update issues of the curve objects
  • Optimize resource clear process
  • Enhance material converter
  • Fix crash when using EEVEE/Cycles with Octane world output
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2024.1.Alpha.3 here:
viewtopic.php?f=33&t=83054
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.5 (4.0)
Octane Server - Studio+ Edition - 29.5
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
