I wanted to test out Octane in Blender, to se if it could work in our pipeline. But after installing the Prime edition (BlenderOctane and Server), I press Blender Octane Edition in Windows Start Menu and Blender 4 starts up (is that correct?).
And I activate the plugin in AddOns, and select Octane as Render Engine I get this in viewport: "Wrong Render-Server version at adress "127.0.0.1"". I have activated the Server with my username. What am I missing?
I use
3D Generalist.
- linograndiotoy
You're using mismatching custom build and server versions. Be sure to downloa dthe right blender and server installers and install using the proposed folders names (which now specify the version number for both Blender and Server).
Thanks, I downloaded the latest ones from the downloadsection.. I will try to find the right ones when I have time.linograndiotoy wrote:You're using mismatching custom build and server versions. Be sure to downloa dthe right blender and server installers and install using the proposed folders names (which now specify the version number for both Blender and Server).
3D Generalist.
- linograndiotoy
Please let me know if the problem persist.
