OOC setting for commandline
SUPERBIEN
Hi there,
I have a render that needs Out of Core features to be able to render. So far I can render with the C4D render queue if I set the OOC to 10G before launching the render.
But when I try to render with commandline.exe, the Octane log windows pops up : "Out-of-core memory limits exceeded"
I wonder where the OOC setting specifying the amount of RAM is stored.
I tried to copy/paste prefs folder from AppData/Roaming/MAXON/Maxon Cinema 4D 2023_BCDB4759 to Maxon Cinema 4D 2023_BCDB4759_x with no luck.
Any help will be appreciated
Windows 10 22H2
C4D 2023.2.0
Octane 2022.1.1-R3 (tried 2023.1.2-R6, same result)
"C:\Program Files\Maxon Cinema 4D 2023\Commandline.exe" -render C:\path\to\scene.c4d -frame 0 1 0
SUPERBIEN
Hello,
I'm feel a bit alone with this problem but I don't want to give up.
I tried to modify OOC settings with a script based on this aoktar post and another one
So far I found indexes I was looking to update but when I try to push those values with c4d.plugins.SetWorldPluginData() the oct.dat file does not update (as it happens when you modify OOC parameter with the gui).
I feel like I need to use another function to achieve this.
Any advice would be greatly appreciated
import c4d
from c4d import gui
ID_OCTANE_LIVEPLUGIN = 1029499
def main():
    #get octane BaseContainer
    data = c4d.plugins.GetWorldPluginData(ID_OCTANE_LIVEPLUGIN)
    #print values for the indexes we are trying to modify
    print("is OOC enabled ? (1 = yes, 0 = no ) => ",data[51])
    print("RAM usage limit =>",data[52])
    print("GPU head room =>",data[53])
    #modify values of OOC settings
    data[51] = 1
    data[52] = 25
    data[53] = 1024
    #store/merge the updated container to C4D pref
    if not c4d.plugins.SetWorldPluginData(ID_OCTANE_LIVEPLUGIN, data, add=True):
        raise RuntimeError(f"Could not store plugin data under id: {ID_OCTANE_LIVEPLUGIN}.")
    #test if the modifications are still there
    test = c4d.plugins.GetWorldPluginData(ID_OCTANE_LIVEPLUGIN)
    print (test[51], test[52], test[53])
    #yes there are but when checking in the GUI it's still the old values. oct.dat does not update
if __name__=='__main__':
    main()
try to copy "oct.dat" from:
`C:\Users\USERNAME\AppData\Roaming\MAXON\Cinema4D-RXX_RANDOM_CODE\prefs\oct.dat` to:
`C:\Users\USERNAME\AppData\Roaming\MAXON\Cinema4D-RXX_RANDOM_CODE_x\prefs\oct.dat` directory.
ciao,
Beppe
