OctaneRender™ for Blender 2023.1.2 - 28.12 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Implement an asset version updater in the Blender Asset Browser
  • Support using node group for scatter surfaces
  • Support preferences to decide "Copy Properties When Changing Node Type" or not(disable kernel node value copy feature by default)
  • Rename the ""Hide Original Mesh" to "Hide Mesh" and move it to the top of octane mesh property panel. Now users can use it to hide mesh in all cases.
  • Disable the "Realtime" option when shared surface is off, which is not available in plugins without shared surface feature
  • Check whether the modifier is actually enabled when processing geo nodes case
FIXES SINCE LAST RELEASE
  • Fix missing Material Output and World Output in the Shader Editor
  • Fix curve edit update issue
  • Fix multi-edit problem
  • Fix the invisible scatter issue when entering edit mode
  • Fix the render problem when involving multiple sockets with the exactly same name
  • Fix issues of "Render as Octane Hair"
  • Fix the missing texture problem when using Octane DB
  • Use fixed offset when adding new node
  • Bug fixes
HOTFIXES 29.4.1 (19/03)
  • Enable Octane addon by default
  • Fix the light beam problem of Analytic light
You can read about new features of OctaneRender™ 2023.1.2 here:
viewtopic.php?f=24&t=82820
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.12.1 (4.0)
Octane Server - Studio+ Edition - 28.12
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Studio+ Edition - 28.12.1
