I hit "delete unused nodes" instead of "solo node" more often than I would like. That wouldn't be so bad if you could cancel it as promised in the dialog box.
neither cancel, nor no to all works. only yes to all seems to work semi-correctly (after hitting it 3-4 times).
would be nice if the dialog would work, or if we could get a separation between the buttons...or some other kind of security mechanism
modo 16.1v8 | studio+ 2023.1.2.199 & 2023.1.2.195
Delete unused Nodes ( unresponsive popup)
- sevengreen
- Attachments
- Deletunusednode4(1).mp4
- (725.64 KiB) Downloaded 7845 times
I am working with Foundry on a fix for this, although it is proving to not be trivial!
This issue is fixed in the next release of the plugin (2023.1.2.200).
