OctaneRender™ for Blender 2023.1.2 - 28.11 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
FIXES SINCE LAST RELEASE
  • Analytic Light displays a light direction in the viewport now
  • Fix the object layer bug when using analytic lights
  • Rollback to default OCIO imager settings if the specified setting is not valid
  • Fix the issue when disconnecting materials from the output node
  • Fix the offset bug when using "rv3d.view_camera_offset"
  • Fix the bug that "Octane DB" uses the legacy nodes
  • Fix saturation value backward compatibility issue
You can read about new features of OctaneRender™ 2023.1.2 here:
viewtopic.php?f=24&t=82820
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.11 (4.0)
Octane Server - Studio+ Edition - 28.11
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
