black image saving
slv
hi all,
My problem :All is ok with octane IPR preview, juste when i press F9, rendering is done normally, at the end when lw save image i get a total black image: setup is with PMC kernel.
If i changed kernel to Path tracing, all is ok : no problem with saving image at the end, i get well the result...
i have the same thing with lw 2023 and lw 2020.0.3
Does anyone have an explanation?
Thank's for help
sylvain
http://www.5500k.fr
Mastoy
Do you use denoising ?
I remember something about PMC Kernel not being compatible with the denoiser
slv
Hi Mastoy,
yes, denoising is activated, i will try without it...
Thank's a lot for your response/help
cordialy
sylvain
http://www.5500k.fr
slv
now there is no more problem, it was well the denoiser which created the problem.
Well done, problem solved
Merci beaucoup
Mastoy
slv wrote:Merci beaucoup
De rien :D
pixym
Hello Slv,
Ce n’est que maintenant que je me rend compte de ton soucis avec le pmc qui n’est pas compatible avec le denoiser…
Sorry
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
Return to “Lightwave 3D”
