OctaneRender™ for Blender 2023.1.2 - 28.10 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
FIXES SINCE LAST RELEASE
  • Fixed an issue of denoiser
  • Fixed an issue of starting final render while preview is on
  • Hotfix: Missing Object Layer Setting restored
You can read about new features of OctaneRender™ 2023.1.2 here:
viewtopic.php?f=24&t=82820
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.10 (4.0)
Octane Server - Studio+ Edition - 28.10
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
