WIP Lighting Challenge #22: The Carnival
livuxman
I'm still practicing with Octane and its enormous capacity to adjust the scene in real time.
So far I have made these tests, but I have not yet opted for one to continue working.
LiVux 64bit | Geforce GTX260 Core 216 and GTX470 | i7 860 | 8Gb | Drivers 275.09.07 | Cuda 4.0.17
James
Wow :O
These look awesome, can't wait to see what you can add to them when Bump and Opacity are available!
Kubuntu 9.04 | Nvidia Gainward 9500 GT | Intel Core2 Quad 2.40 Ghz | 4 GB RAM
livuxman
James wrote:Wow :O
Thank you very much, I will improve or at least I hope so.
pedrofelipe
Wow!
Very good stuff! Lovely atmosphere
livuxman
pedrofelipe wrote:Wow!
Thank you very much
Sam
The rainy mood is perfect !
The water on the ground is really cool also
A little bump for the rain drops circles and it would be perfect :D
livuxman
Sam wrote:The raininy mood is perfect !
Thank you very much. Yes, I plan to use bump map, but there is always the option of using geometry. I also have yet to add some textures.
livuxman
Here I put the current state of the scene. I had to redo it again with the beta2 because I wanted to use the normal map.
The main problem is that on linux hdr fail, so the lighting is not as I want it (with some sun peeking between the clouds), and it can not be achieved with ldr.
Wait for your comments :| .
Phr0stByte
This is coming along really nicely! The one crit I have though, is that scale looks off - as if it is all miniatures... Texturing is really awesome!
Ubuntu Linux 10.10 (Maverick Meerkat) x64 | Geforce GTX285 (Zotac) | x2 Xeon Quads 2.66GHz | 8GB RAM
livuxman
Phr0stByte wrote:This is coming along really nicely! The one crit I have though, is that scale looks off - as if it is all miniatures... Texturing is really awesome!
The truth is that the scale is that everything is miniature and that makes that the depth of field transmit that feeling. I will try to adjust better.
Some particular detail that makes it seem that it is miniatures?
Return to “Works In Progress”
