OctaneRender™ for Blender 2024.1.Alpha.2 - 29.1 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Refactor the camera panel GUI
  • Support "Real-time" option in Viewport rendering
  • Support "Use F-Stop" in Universal Camera
  • Support the feature of copying node data when switching node types
FIXES SINCE LAST RELEASE
  • Fix Blender node menu problem in the Blender's Compositor and Geometry node tree editors
  • Fix an animation render issue
  • Fix the problem that property with default value may not be saved in the .blend
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2024.1.Alpha.2 here:
viewtopic.php?f=33&t=82826
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.1 (4.0)
Octane Server - Studio+ Edition - 29.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 29.1
