X-Particle Spline object does not render stored colors while
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Ofcourse
There seem to be a bug when i use either C4D's deformer on X-Particle generated splines... which also store a color for each, without deformer the trails render the colors fine in Octane, but when I use also deformer on those splines, the colors dont render out using Octane, is that known issue?
It is known problem. Not a thing about us/octane.
Ofcourse
I am not sure what you mean but i have post a bug request to Insydium and they reply to me that it is not problem with X-particles but I should post a bug request to otoy, so here Am I... What to do?
Here is the example scene... https://drive.google.com/drive/folders/ ... sp=sharing
There should be a conflict with them. I'm pretty sure that's a xp problem. Color data lost when a deformer applied. There are not any other method to read in their SDK. They may have a newer one but forgot to update us. I will talk to xp peeps if they deny this.
Can you try your scene with another renderer?
Ofcourse
I have tried to render this in Cycles 4D and it works fine, have you contact them already?
Ofcourse
aoktar wrote:There should be a conflict with them. I'm pretty sure that's a xp problem. Color data lost when a deformer applied. There are not any other method to read in their SDK. They may have a newer one but forgot to update us. I will talk to xp peeps if they deny this.
So I have asked Insydium on their Discord channel here: https://discord.com/channels/4129175115 ... 3424012288
And they reply to me it is probably problem on your side and that your devs can eassily reach them out if you willing to... Because this feature is working also in Redshift.
But I feel, this won't change in near future :(
What is the reason of this feeling?
I'm using the sdk which is provided by them and it's giving black colors in this case. Tell me how this can be a bug on my side? I'm not generating colors from my stuff
Return to “Bug Reports”
