Batch Render Command Line
TheBricksburgTheatre
Hi there,
I tried to batch render from the command line but blender always quits and doesn´t start to render.
Is there a special command i have to add to the the command line? The octane server is running.
In the Forum I found an advise to use the loom add-on but I´m running into the same trouble that blender does not start rendering.
Thank you very much for your help... cheerz
edit:
Problem solved. With the 28.8 version it runs perfectly from the command line
Windows 10, Octane 28.5
linograndiotoy
Great!
Return to “Blender”
