OctaneRender™ for Blender 2023.1.2 - 28.8 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
  • Update to 2023.1.2
  • Add "Checkpoint" AOV nodes
  • Refactor the camera panel GUI
  • Support "Real-time" option in Viewport rendering
  • Support "Use F-Stop" in Universal Camera
  • Support the feature of copying node data when switching node types
New Camera Panel GUI
We have refactored the camera panel in this version. Now options are grouped according to their categories. And on the top of every else, there is a Camera type. Options that are not available in the current camera mode are hidden.
Real-Time Option
FIXES SINCE LAST RELEASE
  • Fix Blender node menu problem in the Blender's Compositor and Geometry node tree editors
  • Fix an animation render issue
  • Fix the problem that property with default value may not be saved in the .blend
  • Minor Bug fixes
  • HOTFIX: Resolved bug with the renderer checkbox option in the Blender Client (all versions)
You can read about new features of OctaneRender™ 2023.1.2 here:
viewtopic.php?f=24&t=82820
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.8 (4.0)
Octane Server - Studio+ Edition - 28.8
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
linograndiotoy
Do not install this build, please. We caught an issue preventing Octane to work.
We'll fix it soon.
Thanks!
linograndiotoy
We fixed the issue, but we still need to update the download link in the main post.
Meanwhile, you can use this one:
https://render.otoy.com/plugindownloads ... stable.exe
Last edited by linograndiotoy on Wed Jan 24, 2024 7:24 am, edited 1 time in total.
linograndiotoy
All links in the main post have been updated to the correct versions.
