OctaneRender™ for Blender 2024.1.Alpha.2 - 29.0 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to 2024.1.Alpha.2
  • Add new blend output AOV layer node "Texture". This allows you to use any texture (including OSL textures) in the compositor.
  • Add new texture node "Output AOV parameter" which allows you to access output AOVs in textures. If used outside of the compositor, it produces black.
  • Add support for the Intel Open Image Denoiser to the Camera imager node and as an output AOV layer.
  • Add 2 new visible beauty render AOVs which are used by the denoisers, but can also be used in the compositor as inputs for the Open image denoise output AOV layer: Denoise albedo AOV and Denoise normal AOV
  • Add a new "Apply LUT" layer for the "Composite texture".
  • Add a new "Apply custom curve" layer for the "Composite texture".
  • Add option "Direct light rays" to the kernel nodes that trace paths. This option determines how many light samples we calculate for the first high-roughness / diffuse bounce. Calculating more light samples can reduce noise, when many light sources are used and the direct light contribution is significant.
  • Add new pin "Volume padding" to all medium nodes to expand the bounding box of a volume, if the "Sample position displacement" input is connected. This is useful if you are using sample position displacement, which can cause the displaced volume to go out of bounds.
  • Add new node "Frame index" (under "Values" -> "Utilities") which allows you to fetch the frame index of the current project time plus an offset and use it for other operations.
  • Add option "Round edges visibility" which gives control over whether the object layer geometry is visible to the rounded edges calculation.
  • Add new Light mixer output AOV layer node. This has the same functionality as the old Light mixer output AOV node, which is now hidden.
  • Make the Legacy output AOV layer node visible to allow output AOVs of older scenes to be used as layers in the new output AOV node.
  • Add the following new output AOV layer nodes, which can be used to store an image during compositing and recall it in a higher layer and make it easier to build reusable effects, and can improve performance by preventing repeated work:
  • Add new Sharpen output AOV layer node.
  • Support two new passes(denoise albedo and denoise normal) in the classic render passes
FIXES SINCE LAST RELEASE
  • Implement movable sockets in the Mask With Layer Group nodes
  • Implement image file node
  • Fix the problem that property with default value may not be saved in the .blend
  • Use the Blender node menu for the Blender's Compositor and Geometry node tree editors
  • Minor Bug fixes
HOTFIXES - 16/01
  • Fixed an issue when setting "Denoise Type"
You can read about new features of OctaneRender™ 2024.1.Alpha.2 here:
viewtopic.php?f=33&t=82826
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.0 (4.0)
Octane Server - Studio+ Edition - 29.0.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 29.0.1
