Cinema4D version OctaneRender® 2024.1_Alpha2-R3 (20.01.2024)
Hi all,
This is the plugin build based on OctaneRender® 2024.1 Alpha 2 SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching OctaneRender® 2024.1 Alpha 2.
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 522. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
The minimum supported macOS version is 14. If you depend on using an older version, please let us know.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models. On macOS, only the CPU version is supported.
As with all experimental builds, we advise to not use this release for production purposes. We are trying to, but we can't guarantee that scenes saved with this version will be compatible in future releases. Changes are being made daily.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2024.1_Alpha_2-[R3] plugin revisions
  • New: Added Octane_PNG format for saving render AOVs
  • New: Instance_Color support on spline_to_hair with normal/render_instances mode with Cloner objects
  • New: Spline (render instance mode) support with Cloner objects
  • Fix: Post parameters in Camera tag
  • Fix: Loosing the filename in Volume objects
  • Fix: C4D 2024: Crash on scatter when we edit a distribution surface
  • Fix: Missing take support for Color GUI
2024.1_Alpha_2-[R2] plugin revisions
  • Some update improvements, fixes
  • A fix for OCIO rendering with Teamrender
  • Some fixes on LV
2024.1_Alpha_2 revisions
  • Added new Light mixer output AOV layer node. This has the same functionality as the old Light mixer output AOV node, which is now hidden.
  • Made the Legacy output AOV layer node visible to allow output AOVs of older scenes to be used as layers in the new output AOV node.
  • Added "Subtract" and "Divide" blend modes to the Legacy output AOV layer node.
  • Added pin "Affect occlusion only", which controls whether only the alpha channel is modified, or whether the (premultiplied) RGB channels are also modified, to the following output AOV layer nodes:
    Adjust opacity
    Mask with layer group
    Mask with Cryptomatte
  • Added the following new output AOV layer nodes, which can be used to store an image during compositing and recall it in a higher layer and make it easier to build reusable effects, and can improve performance by preventing repeated work:
    Save checkpoint
    Load checkpoint
    Discard checkpoint
  • Added new Sharpen output AOV layer node.
  • The "Camera imager" node type is now called "Imager", because it's not related to cameras.
  • The Imager node's "Saturate to white" pin is now called "Clip to white".
  • Added option to switch between shading and smooth normals in the falloff texture node. This also fixes the problem that the mode "Normal vs. eye ray" did not take bump mapping into account.
  • Refactored how we allocate memory for the denoiser buffers: Buffers required by the denoiser will be allocated before we upload the scene data to make sure that we have the required memory available to run the denoiser when needed. This should solve cases where the denoiser failed due to an insufficient amount of available memory.
  • OSL: Added ray type "direct" to the OSL function raytype() to match direct light rays.
WINDOWS STUDIO+ 2024.1_Alpha_2-[R3] (R15-R2024)
https://render.otoy.com/customerdownloa ... R3_win.rar
WINDOWS STUDIO+ DEMO 2024.1_Alpha_2-[R3] (R15-R2024)
https://render.otoy.com/plugindownloads ... R3_win.rar
Mac OSX Prime 2024.1_Alpha_2-[R3] (R25-R26/R2023/R2024)
https://render.otoy.com/customerdownloa ... R3_OSX.zip
Please note the macOS build below will only work correctly on macOS 13.3 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.1.0). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
SSmolak
Thank you for fast update.
Issue with removing AOV inputs. It remove all of them.
aov.zip
(83.46 KiB) Downloaded 277 times
cjadams
Do we have a 2024.x Render node yet for windows by chance to work with this new build?
SSmolak wrote:Thank you for fast update.
Yes, it's how works
cjadams wrote:Do we have a 2024.x Render node yet for windows by chance to work with this new build?
You'll have the answer if you look to standalone topic
cjadams
I found it.. first time doing render nodes on this end.. so.. yeah I figured it out just thought I would confirm
cjadams
FYI - soon as I enable network rendering then hit the network settings button. I get endless Mac beachball.
M2 Ultra Mac Studio latest c4d on both the Mac and pc and 2024.x daemon running on the PC
jmelpri
Hi, I just installed this new version to test network rendering between my PC and my Mac. I have installed 2024 render node on my PC and the Mac rendering is working through the standalone application, but it doesn't show any nodes when I go to C4D. Can you guys give me any hints on what I could be doing wrong? Thanks !
cjadams
seems most of my beach balling was from the octane plugin being in /applications/...plugins/. rather than the other path of /home/library/preferences/maxon/.....plugins
once I moved it there things were much better.. I assume its a read/write privilege issue..
as for adding in the machine install and run the daemon on the PC and start it so you have the cmd window showing..
I also installed and tested octane standalone and c4d octane was loading in c4d on the PC as well ..then all you should need to do is run the daemon on the pc..
and run cinema on Mac enable network rendering and ADD the IP address of the PC and bind...
then it seemed to just work for me!
Raoul
Excited for the network render support. Havent had much luck yet though unfortunately.
Latest build of C4d on an Apple M2 Ultra networking to a pc with two 3080TIs.
Recognizes the slave fine in the settings but when rendering does one of two things.
1) If its a very simple scene like a cube and sunlight - it lists gpu2/2 but has no effect on actual render time...
or 2) a more complicated scene, ie a 3d model of a truck.. it says 0/2 for the Gpus and never actually finishes updating.
anyone else having this issue, any workarounds?
