OctaneRender™ for Blender 2023.1.1 - 28.7 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
  • Integrate to the Blender 4.0
  • New imager and postprocess GUI panel
  • Update imager/postprocess UI and "gray-out" feature, for better indication of which imager/postprocess is currently active
  • Add "Always use Raw View Transform for Octane" in the color management panel
  • Move "Octane Output" to the root level of the Output property panel
  • Add "Octane Output Path" and "Reuse Blender's Output Path". Now users can specify an independent output path for Octane
FIXES SINCE LAST RELEASE
  • Fix a couple of update issues when using viewport render
  • Update the material converter to adapt to Blender 4.0
  • Minor Bug fixes
HOTFIXES (v28.7.1)
  • Fix the missing nodes when using Cycles engine
  • Bring the "Group" and "Layout" back in the Octane menu
  • Added missing options to the 'Mask With Layer Group' node
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2023.1.1 here:
viewtopic.php?f=24&t=82700
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.7.1 (4.0)
Octane Server - Studio+ Edition - 28.7
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
linograndiotoy
Known issue: when Octane addon is enabled, it's not possible to add Cycles nodes. We'll fix this ASAP.
