Team Render & OCIO
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
bartjeeh
Ok, i have an issue with Team render and OCIO.
In the default scenario it works great, however if frames need to be re-assigned, there seems to be an issue.
Here are the steps i think are happening
1. Start teamrender, distribute frames over pc's (all pc's will render fine including OCIO)
2. When frames get redistributed (e.g. a new set gets asigned to a pc because one is quicker than another), this pc drops out with the message "Select some OCIO color space!!!"
3. this happens to each and every system that needs to get new frames. Due to this messsage being an octane message, c4d doesn't kick it out of the teamrender group and thus waits for its frames.
4. when we click the message, it gets kicked out of teamrender and another pc is assigned.
5. due to every pc losing its OCIO color space reference after getting reassigned, the render fails with ~10% of the frames left.
From what i can see.
A. There is no problem with OCIO as all pc's work for the first entire batch, till reassignment. (i have tried to move it to C://, i have tried to make it an environment variable), same thing.
B. This is not version related, as i had this since C4D 2022 and octane 2021 and have just ran into the same issue in C4D 2024 and Octane 2023.
C. i cannot fix this without developer help.
What seems to be the issue
Primary: some ocio relinking is not triggered upon the second frame assignement by team render. (or for some other reason octane suddenly says "Select some OCIO color space!!!"
Secondary: when pc has issue with octane, it doesn't get kicked out of team render team, and therefore host waits for it till button is clicked, it should be kicked regardless of the button being clicked. Otherwise headless rendering is pretty pointless. :)
Below are the logs
OCIO color space to continue with the current OCIO option!!!
FRAME:82 fps:30
MB:0/0 ST/MOV:0/21 Nodes:78 Tris:73k DispTris:0 Hairs:0 Meshes:23
Textures Grey8/16:0/0 Rgb32/64:0/1
VRAM used/free/max:1.553Gb/17.951Gb/23.999Gb Out-of-core used:0Kb RAM used:18.321Gb total:31.897Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=0.005sec. updateTM=0.253sec. renderTM:9.97sec. totalTM:10.229sec.
FRAME:180 fps:30
VRAM used/free/max:1.554Gb/17.216Gb/24Gb Out-of-core used:0Kb RAM used:26.444Gb total:63.906Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=0.006sec. updateTM=0.474sec. renderTM:89.28sec. totalTM:89.761sec.
bartjeeh
@Aoktar, do you have any idea what this could be?
DinoMuhic
You need to copy "oct.dat" from prefs of master C4D which is set to proper OCIO config to "Cinema4Dxxxxxxx_c/teamrender_client" directory. This directory can be found under preferences part in the Client.
I found it's a different issue just happens with clients in Net render mode. I'm trying a fix...
Return to “Bug Reports”
