OctaneRender2023.1.0.2 Solaris19.5.805&20.0.506-RC5 OBSOLETE
BK
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender 2023.1.0.2 Solaris19.5.805 - RC5 and Solaris20.0.506 - test.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrates completely with Houdini 19.5 Solaris.
What is OctaneRender for Solaris?
The OctaneRender for Solari's plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launching it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
-Houdnin Packages/json installation steps-
- Please create a folder inside Documents\houdini19.5 and name it as Packages
- Open notepad or any text editor and use these lines
    "enable" : true,
    "env":
        "OCTANE_AUTOSPAREPARAMS" :
            "value": 1,
            //location to your octane folder (example below)
            "OCTVERSION": "PATH\TO\OCTANESOLARIS\Win64FOLDER",
            "HOUDINI_PATH" :
                "value": "$OCTVERSION",
            "PATH" :
                "value": "$OCTVERSION/bin",
            "PXR_PLUGINPATH_NAME" :
                //if you have the Solaris version installed
                "value": "$PATH\TO\OCTANESOLARIS\dso\usd_plugins",
- Then Save as OctaneSolaris.json
- Please make sure to disable the .env paths
New features
To learn more about the new features and improvements of OctaneRender 2023.1 and the Render Node app, please check out the 2023.1 release post
- Change log since last release[Test]-
Note: Click the link below to refer to Important SOP to USD attribute conversion
https://www.sidefx.com/docs/houdini18.5 ... mport.html
-Known Issues-
- Solaris rendering extra beauty AOV with Octane node and currently investigating
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
However, the usual Octane light linking works as expected.
- Deep AOV is yet to support!
Important: if using macOS, we strongly recommend that you update to version 13.3. Prior to 13.3, there is an OS-related issue that causes a render failure consistently if you render for long periods of time.
Studio+ Subscription Downloads
2023.1.0.2 - Houdini 19.5.805
2023.1.0.2 - Houdini 20.0.506[Test]
macOS build Downloads for ARM64
Linux build Download
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
snakeboxmedia
I really REALLY hate how you guys release 2023.1.0.3 and then 2 hours later you release the solaris build, Built NOT on the same version... like wtf.
This now means the solaris build isn't for the latest production build and doesn't have the critical fixes that was added in 2023.1.0.3 ? like how is there no communication on this, to at least pretend to try and keep things releasing as one product. freaking blows my mind how bad this feels as an end user.
How tied is the solaris part of this to that version? could I replace the non-solaris build in this release with the more recent one without everything blowing up or?
lavrenovlad
This is how things go here :D
lavrenovlad
When I rotate my camera in the scene, when I release mouse the viewport while rendering freezes for a few sec, even some compression/lower resolution can be seen for a second too. Is that some sort of update going on after I release the mouse button? Kinda ruins the smoothness of the working process
BK
snakeboxmedia wrote:I really REALLY hate how you guys release 2023.1.0.3 and then 2 hours later you release the solaris build, Built NOT on the same version... like wtf.
Hi Snakeboxmedia,
Please understand that OctaneRender for Houdini and OctaneSolaris plugin have different development pipelines.
Octane Solaris is being developed by another programmer and is based on Hydra, not the Houdini SDK. It does not share any of the same code as the main Octane Houdini plugin.
When the main Houdini plugin is released we often have little or no warning.
We encounter different issues/bugs like every other software. However, we will do our best to sync in the future.
As we have mentioned earlier, we prefer to release our main plugin as soon as it passes internal QA. We never intend to let the main plugin users wait.
No, please do not replace or alter our plugin files.
cheers
Kind Regards
bk3d
galleon27
BK wrote: Hi Snakeboxmedia,
cheers
That sounds like an internal issue that we as users (and paying customers) shouldn't be dealing with.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
