Environment map randomly not loading
brutesque
I'm rendering with team render. I have a file that contains about 10 takes. I'm sending all the takes to the Team Render Queue. All the takes are using the exact same assets. But 30% of my queue will have not loaded the environment map and will have rendered black frames (since i have no other light sources). At this point rendering with Octane is a gamble wether the renders are gonna be ok. My scenes are super super small and simple, i'm just rendering some spline extrudes, nothing fancy. I can see in the team render client log that the asset was successfully loaded.
The team render machine is using c4d 2024.1.0 and 2024.2.0 and OctaneRender 2023.1
I believe that you made same post on other topic and I replied you, isn't?
viewtopic.php?f=30&t=82222&sid=8d6dd0b3 ... 8a#p429969
