Cinema4D version 2023.1.1 (Obselete stable) 13.12.2023
Hi all,
This is the plugin build based on 2023.1.1 stable SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching Standalone 2023.1.1.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
Important: if using macOS, we strongly recommend that for macOS, you use at least 13.3 or preferably newer.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2023.1.1 plugin revisions
  • Pyro wrong matrix fix for some cases(when we have zero sized channels)
  • Picture Viewer: Copy buffer error with some CPUs
  • Added support for multi-instances on xpScatter
  • AB mode line selection has higher priority over pick DOF/material mode
  • A possible crash case in OSX when Live Viewer closed
  • Minor revisions
WINDOWS STUDIO+ 2023.1.1 (R15-R2024)
https://render.otoy.com/customerdownloa ... .1_win.rar
WINDOWS STUDIO+ DEMO 2023.1.1 (R15-R2024)
https://render.otoy.com/plugindownloads ... .1_win.rar
Mac OSX Prime 2023.1.1 (R25-R26/R2023/R2024)
https://render.otoy.com/plugindownloads ... .1_OSX.zip
Please note the macOS build below will only work correctly on macOS 13.3 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.1.0). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
SSmolak
Transmission PBR textures still loading with wrong 1.0 gamma value.
PBR Auto works the same as Auto + Connect
Does C4D Octane version has Material switch node like Standalone ?
911ljt
The newest update of C4D 2024.2.0 has ton of bugs when pair with Octane, Sometimes it will render a Whole Black PNG with transparent background.. Sometimes when I click the render button, this particular version of C4D will require much longer time to prepare and load the asset to the live viewer (3-5 sec longer). And another annoying bug and the most important one is bothering me so bad. Please check the screenshot below. I post a sample setting file below. Am I doing something wrong here? As long as I try to render a PNG with Alpha, the picture viewer color is getting washed out like few years ago when I first have this problem....... :oops:
Yes, I know how to fix it before and the end result is good no matter what, I used to fixed it by disabling the C4D internal Color Profile setting, but that button cannot do anything now.
Please check the project file below and kindly point me where I did wrong. Is it a bug or feature?
Thank you in advance!
the sample project file with render setting
TEST.zip
(143.32 KiB) Downloaded 204 times
Thank you!
911ljt wrote:The newest update of C4D 2024.2.0 has ton of bugs when pair with Octane, Sometimes it will render a Whole Black PNG with transparent background.. Sometimes when I click the render button, this particular version of C4D will require much longer time to prepare and load the asset to the live viewer (3-5 sec longer). And another annoying bug and the most important one is bothering me so bad. Please check the screenshot below. I post a sample setting file below. Am I doing something wrong here? As long as I try to render a PNG with Alpha, the picture viewer color is getting washed out like few years ago when I first have this problem....... :oops:
TEST.zip
While saying tons of bugs? You say a fews...
Btw did you try without GSG in environment object? Performance difference maybe related to this.
Also I can see the black environment on some restarts on to LV.
Last, I'm on 2024.1.0 and no problem with "color profile settings". It works well here, I'll try with 2024.2.0
UPDATE: "Enable color profile" is not doing anything with 2024.2.0. Maxon is internally changing the stuff and this causing several problems. I have to find and fix the issues when they do something is working different. It may be related this changes or a bug, not sure. Stay with previous build if it's possible.
SilentPartnersStudio
Awesome!
This release fixes the limit on emissive texture, fixes the flipped disc for area lights, and also fixes some issues with analytic light exposure changing when other lights are disabled.
So far great update
911ljt
TEST.zip
Thanks ahmet for your incredibly fast reponse, I will tried to upload a scene when the bugs i memtion can be generated 80%. they happened too randomly and I m now switched back to 2024.1 for good measure. They definately change a few thing with third party plugin and made some wierd bug along the way.
Thank you for notifying the Color profile setting bug!
Thank you!
Tell me the issues that you encountered after the Maxon updates, 2024 is most bloody movie of the guys.
thanulee
aoktar wrote:Tell me the issues that you encountered after the Maxon updates, 2024 is most bloody movie of the guys.
Haha that is so true.
I have also a ton of issues, octane not showing objects, rendering black frames, crashing.
All these when I cache dynamics, but does not seem octane related. Seems to me that this new viewport is very bad at updating priorities of cached objects.
haineicunzhiji
The attachment Screenshot.png is no longer available
The attachment TEST.zip is no longer available
I have used your project to render it, and there is no problem in rendering it as a picture, it has transparency.
Maybe you should open "Image Transparency",
It will display transparency correctly in the c4d image viewer. Even without opening it, it just doesn't show transparency.
The rendered picture is correct.
Image Transparency
Image Transparency
C4D 2025.3.3 @ win11|i7-14700k|Geforce RTX4080super|64GB
Okay, just an update, we were trying to run the plugin in C4D 2023.
It runs okay but the render settings don't show up when we try to set them.
