Rendered viewport doesn't update when moving an Octane Light within the scene.
Steps to reproduce:
1. Load the Octane Default Startup file
2. Add an Octane Area Light
3. Switch to Rendered Mode
4. Translate Octane Area Light, viewport doesn't refresh.
5. Translate Default Cube, viewport refreshes but the Area Light doesn't update its position.
Version: 2023.1.1 v28.6 Non-Addon
[28.6] Rendered Viewport not updating when moving lights
C. RAM Capacity (i.e. 6 GB)
Same here.
System – Windows 11
System – Windows 11
- AlexeyAdamitsky
Transforming, rotating and scaling lights doesn't update it in IPR. This is a serious issue. I can barely work since I have to restart IPR each time I do a change. It's a critical bug.
PLEASE FIX IT ASAP AND PUBLISH AN UPDATED VERSION
- AlexeyAdamitsky
Thanks. Please publish the updated version. I need it for work.linograndiotoy wrote:That's been fixed.
- linograndiotoy
We still need to update the file in the release post. Sorry about that.
Meanwhile, please use those links to download the builds solving the issue. Thanks!
(First link is WIN, second Mac, third Linux.)
-Fix the data missing issue when appending color ramp node
-Fix the render issue when moving lights
https://render.otoy.com/customerdownloa ... stable.exe
https://render.otoy.com/customerdownloa ... stable.zip
https://render.otoy.com/customerdownloa ... stable.run
- AlexeyAdamitsky
Thanks. The bug is fixed now. Octane was practically unusable with this bug since the lighting is a core part of rendering.
