OctaneRender™ for Blender 2023.1.1 - 28.6 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
  • Update to Octane 2023.1.1
  • Optimize the synchronization of geometry nodes
  • Optimize the synchronization of scatter nodes
  • Support up to 2 color attributes even if there is not an active one
HOTFIX (12/12)
  • Fix the data missing issue when appending color ramp node
  • Fix the render issue when moving lights
  • Update the version number to 28.6.2
  • Fix the Meta ball update problem
  • Fix the light masking update problem
FIXES SINCE LAST RELEASE
  • Fix some OSL compilation problems
  • Fix the disconnection problem when updating the composite texture layer node to 2023 format
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2023.1 here:
viewtopic.php?f=24&t=82700
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.6.2 (3.6.5)
Octane Server - Studio+ Edition - 28.6.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
linograndiotoy
Please use those links to download the most updated version, which fixes the light update issue. First link is WIN, second Mac, third Linux.
-Fix the data missing issue when appending color ramp node
-Fix the render issue when moving lights
https://render.otoy.com/customerdownloa ... stable.exe
https://render.otoy.com/customerdownloa ... stable.zip
https://render.otoy.com/customerdownloa ... stable.run
