Repeat Image Sequence
Kilian
Image sequences are working on the fly in Modo. But I can't get it to repeat. It stops at the last frame. End Behavior is Repeat.
With an Octane Override and some tweaks the image sequence is also working. But no repeat here either.
Is this possibe?
Checking the code - the plugin is using the Modo SDK to determine the image filename to load based upon the start frame, end frame and repeat settings. So perhaps there is something specific with your scene setup which is causing the issue. Can you send me a simple scene that demonstrates this problem please?
Edit to the above - this appears to be a Modo SDK bug. I have quizzed Foundry on it.
Kilian
Hi Paul, thanks for your reply. So wait to see what Foundry says about this? And you don't need a simple scene?
I have modified the plugin to support Clips->Image Sequence->End Behavior=Repeat in the next release. You can try this in the test build posted on the #octane-for-modo Foundry Modo slack channel.
Return to “Foundry Modo”
