1. The material does not show when added to an object. Rendering needs to be restarted in order to material show in render view. This happens in 28.5 nonaddon.
2. Shading type does not change in render view. In order to make it work you need to go to edit mode and go back. This happens in 28.5 nonaddon and addon.
Preview update issues
C. RAM Capacity (i.e. 6 GB)
System – Windows 11
System – Windows 11
- Andreas_Resch
Also when you disconnect a Material node from the Output node or delete the Material node, the preview rendering doesn't update. This happens in the 28.5 addon version (I can't check it in the non-addon one).
here is a video showing the problem:
https://vimeo.com/889183447/db694c236e?share=copy
oliver
oliver
Another preview update issue when using modifiers. When toggling "Realtime" modifier the render preview does not update.
System – Windows 11
System – Windows 11
Looks like these issues are fixed in nonaddon version 28.6
System – Windows 11
System – Windows 11
