OctaneRender 2023 for Inventor [OBSOLETE]
Autodesk Inventor (Integrated Plugin developed by Paul Kinnane)
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Inventor - TEST and STABLE releases.
Inventor Version
The plugin requires Inventor 2022, 2023 or 2024, Windows 64bit.
IMPORTANT : Inventor 2023 - after installation of the plugin, go to Tools->Add-Ins and on OctaneRender for Inventor UNTICK Block and TICK Loaded/Unloaded and Load Automatically.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Inventor version and build number
- OctaneRender for Inventor version (ie. 1.20.1.10)
For more information
- Read the on-line manual
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Current STABLE build (Octane 2023.1.2)
Previous STABLE build (Octane 2023.1)
Release Notes
2023.1.2.32 (4-Mar-2024)
- Compiled with Octane 2023.1.2
2023.1.0.32 (27-Nov-2023)
- Added all new Octane 2023.1 Output AOV, Textures and Texture Layer nodes
- The Compositor pin on the Rendertager is now the Output AOV pin
- Added Iridescent node (which was previously missing)
- The Composite nodes from Octane 2022.1 are now in the Output AOV pin of the Rendertarget
- Added all Texture Layer nodes from Octane 2023.1
- Added the Interpolation Color Space pin to the Volume Gradient, Gradient Map and Toon Ramp nodes
- Added Dispersion Mode to the Standard Surface Material, Specular Material, Specular Material Layer, Universal Material. This defaults to "Abbe number". Change this to "Cauchy formula" in order to render as per Octane 2022.1
- Added Cast Photons to the Environment
- Added the Enabled pin for each material input of the Composite Material
- Not implemented
  • * Switch nodes
    * Analytic and Directional lights
    * Custom LUT
    * Saving in TIF and JPEG formats
    * The Apply custom curve, Apply LUT, Apply OCIO Look, Convert for SDR display (OCIO), Mask with cryptomatte nodes
I have updated the installers at the top of this thread with:
2023.1.2.32
helluvapixel
Hi Paul, when will the plugin be updated for Inventor 2025? I upgraded without realizing the latest supported is 2024.
helluvapixel wrote:Hi Paul, when will the plugin be updated for Inventor 2025? I upgraded without realizing the latest supported is 2024.
Have you tried the plugin with Inventor 2025? I would have thought it would work unless there was a major change with Inventor 2025.
It looks like Inventor 2025 is updated to the latest Dot Net framework. I will post a release to address this in the next 24hrs.
Inventor 2025 update from .NET 4 to .NET 8 for addins, and results in the Octane plugin not compiling or running. So this will time me some time to resolve. Sorry for the delay.
I still have some issues to address (there is no Octane icon on the toolbar for example), however for me, this version seems to run on Inventor 2025. Does this work correctly for you please?
https://render.otoy.com/customerdownloa ... STUDIO.exe
Return to “Autodesk Inventor”
