Wordl Creator bridge
iDlart
Hello.
I bought octane render on black Friday. and decided to try World creator. i have a problem that i can't download bridge because i don't have an account. how to solve the problem ?
Labrats
Same problem here. I read on the facebook group of octane that the team of World creator is sending over their bridge files. Curious when otoy will present them to us. Can't wait! :-)
jc0
I have a World Creator account and can download the Bridge plugin for Cinema 2024. However, I can't get it to work... the bridge.xml that's referred to in the plugin's settings, doesn't exist. Is this a known issue with the Otoy Black Friday version of World Creator 2023?
jayroth2020
You need to access the bridge in Cinema 4D via Extensions > World Creator Bridge. Then you need to ensure that the location of the bridge.xml file in the World Creator Bridge dialog is correct. In my installation, the file was located in Documents > World Creator for Octane > Sync. Don't forget, you should also save the WC file you are working on, so that it resides on disc. The name of that file should also appear in the Asset Name field of the World Creator Bridge dialog. If it is not there, you need to add it yourself.
jalejune
@jayroth2020 just installed the World Creator for Octane 2024.2 application and in Documents\World Creator for Octane there is no sync folder nor bridge.xml. Only folders for Export, Screenshots and Versions. Also noticed in WC for Octane 2024.2 there is no "sync" button across the top right nav like in pictures shown in documentation on WC support site & .pdf that came with Bridge download .zip linked from Otoy Downloads > Asset Packs > WC > Bridge tools (External) link > Cinema 4D 2024 (download).
I see and can open the extension in C4D but can track down a Sync folder or a bridge.xml file to link it to with install of WC for Octane 2024.2
Any advice? Would appreciate the help.
