OctaneRender 2023 for Revit [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit - TEST and STABLE releases.
Revit Version
This version runs on Revit 2022, 2023 and 2024 on Windows Windows 7, 8, 10 and 11, 64 bit.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
- If relevant - supply the Journal file for the Revit session where the support issue occurred. Journal files can be found in C:\Users\[username]\AppData\Local\Autodesk\Revit\Autodesk Revit [Revit version]\Journals
For more information
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Revit/?page_id=536
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Download Links
Current STABLE build (Octane 2023.1.2)
Previous STABLE build (Octane 2023.1)
Release History
2023.1.2.72 (4-Mar-2024)
- Compiled with Octane 2023.1.2
2023.1.0.72 (22-Nov-2023)
- Added all new Octane 2023.1 Output AOV, Textures and Texture Layer nodes
- The Compositor pin on the Rendertager is now the Output AOV pin
- Added Iridescent node (which was previously missing)
- The Composite nodes from Octane 2022.1 are now in the Output AOV pin of the Rendertarget
- Added all Texture Layer nodes from Octane 2023.1
- Added the Interpolation Color Space pin to the Volume Gradient, Gradient Map and Toon Ramp nodes
- Added Dispersion Mode to the Standard Surface Material, Specular Material, Specular Material Layer, Universal Material. This defaults to "Abbe number". Change this to "Cauchy formula" in order to render as per Octane 2022.1
- Added Cast Photons to the Environment
- Added the Enabled pin for each material input of the Composite Material
- Not implemented
  • * Switch nodes
    * Analytic and Directional lights
    * Custom LUT
    * Saving in TIF and JPEG formats
    * The Apply custom curve, Apply LUT, Apply OCIO Look, Convert for SDR display (OCIO) nodes
I have updated the installers at the top of this thread with:
2023.1.2.72
JNDesign
Hi Paul
How far is 2025?
thanks
I will test an Octane 2024.1 version of the plug for Revit 2025 here in the next 24hrs for you to test.
Revit 2025 upgrades the version of C# DOTNET from 4 to 8, so there are a lot of issues caused by this. It is going to take a few days to sort through this before I can post a Revit 2025 version of the plugin, sorry.
Following is a TEST version of the plugin for Revit 2025. Please note that it is compiled with Octane 2024.1 Beta 2, so keep a copy of your .rvt files saved with Octane 2023 in case you need to revert back.
2024.1.0.73
- Compiled with Octane 2024.1 Beta 2
- Added the 2024.1 features from viewtopic.php?f=33&t=82267
- The "Output AOV"->"Apply Imager and Post Processing" node from Octane 2024.1 has not been added to the plugin
- The "Value"->"Time" node from Octane 2024.1 has not been added to the plugin
- Added support for Revit 2025
https://render.otoy.com/customerdownloa ... STUDIO.exe
Return to “Autodesk Revit”
