XParticles Radius Not Diameter
snahbah
When you add an Octane tag to an emitter and set to geometry. The particles sizes don't match. Looks like it is taking the diameter value and using it as a radius - so the IPR particle size looks like it's double that of the viewport.
Oh, and thanks for all your hard work, much appreciated
snahbah wrote:When you add an Octane tag to an emitter and set to geometry. The particles sizes don't match. Looks like it is taking the diameter value and using it as a radius - so the IPR particle size looks like it's double that of the viewport.
you may need to assign a proper geometry with proper size
