OctaneRender™ for Blender 2023.1 - 28.5 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
  • Update to Blender 3.6.5
FIXES SINCE LAST RELEASE
  • Fix the compatibility issue of the "Composite Texture Layer" nodes
  • Fix a motion blur problem when using Symmetric alignment
  • Organize the UI layout of the octane mesh properties
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2023.1 here:
viewtopic.php?f=24&t=82229
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.5 (3.6.5)
Octane Server - Studio+ Edition - 28.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
