Isolating objects doesn't work (addon 28.4)
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Andreas_Resch
Isolating an object in Render Preview mode doesn't work. It just centers the objects but the other objects are still visible. Works fine in the other two view modes.
Addon version 28.4, Windows.
linograndiotoy
Thanks Andreas, we'll fix that!
Andreas_Resch
It basically works, but because of some problems in the code, the isolation process becomes almost unusable in bigger scenes. I've just submitted a bug report for that issue. I guess once you fix that, the isolation should be fine as well.
Return to “Bug Reports”
