OctaneRender™ for Blender 2023.1 - 28.4 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
  • Update to 2023.1
  • Update to Blender 3.6.4
  • Add more safe checks before enabling shared surface
FIXES SINCE LAST RELEASE
  • Fix a problem of analytic lights casting volumetric lighting
  • Fix a UDIM issue
  • Fix an update issue of OCIO color space nodes
  • Various minor bug fixes
HOTFIX: UPDATED on 27/10
  • Fixed an issue with UDIMs
You can read about new features of OctaneRender™ 2023.1 here:
viewtopic.php?f=24&t=82229
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.4 (3.6.4)
Octane Server - Studio+ Edition - 28.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
